Stuartd
Message 1 of 65
Webpages not loading generally slow
I am based in Rotherham, not sure what is happening but it started this morning. Pages not working timing out and generally being slow.
64 REPLIES 64
john46
Message 2 of 65
Re: Webpages not loading generally slow
Hi have you used the status board or Phoneline for any problems in your area https://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31 or 08001690199
Stuartd
Message 3 of 65
The online fault checker isn't working, rang the number and my location wasn't listed. My Internet is timing out on my wired connection as well which would rule out wifi, all the lights are green on the open reach modem.
scalow
Message 4 of 65
I am experiencing a similar issue that started this morning as well. Every few minutes a page will fail to load or load very slowly. Certainly something not quite right, because my connection is normally perfect. I'm in Chesterfield, so it might be a local issue.
I've changed DNS servers to Google DNS and still getting the same problem.
ryant704
Guru
Message 5 of 65
I had the same yesterday, seems resolved this morning.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Stuartd
Message 6 of 65
This is happening again to me after being fine towards the later part of last night, however its back Arnold style and it almost feels like a DNS problem with pages timing out as I can still download at full speed. Any one got any ideas?
scalow
Message 7 of 65
I'm still experiencing the same problem. Sometimes pages don't load or load very slowly, but like you say download speed is unaffected, I'm running at full speed when it works. It's not a DNS issue because I've changed to both Open DNS and Google DNS and have the same problem. I think there's an issue in the network causing packet loss. I've done these tests that show there's a problem:
Ping statistics for 212.58.241.131:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 12ms, Average = 12ms
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.0.1.1
2 5 ms 5 ms 5 ms 217.32.143.133
3 5 ms 5 ms 5 ms 217.32.143.158
4 6 ms 6 ms 6 ms 213.120.181.166
5 6 ms 6 ms 6 ms 217.41.169.47
6 6 ms 6 ms 5 ms 217.41.169.107
7 5 ms 5 ms 5 ms 109.159.251.79
8 16 ms 15 ms 15 ms core1-te0-5-0-7.ealing.ukcore.bt.net [109.159.251.21]
9 12 ms 11 ms 11 ms peer2-xe1-0-0.telehouse.ukcore.bt.net [109.159.254.104]
10 25 ms 11 ms 11 ms 194.74.65.42
11 * * * Request timed out.
12 13 ms 14 ms 13 ms ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
13 14 ms 20 ms 14 ms 132.185.255.60
14 * 12 ms 12 ms 212.58.241.131
Trace complete.
dhj
Message 8 of 65
HI, I have had the same problem for the last couple of days. I am also based in Chesterfield - there seems to be a theme here! Is anybody in authority investigating this on our behalf please?
Bullitt
Distinguished Expert
Message 9 of 65
not unless someone has contacted the mods
Stuartd
Message 10 of 65
This is what mine looks like from a ping perspective;
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Stu>ping www.bbc.co.uk -t
Pinging www.bbc.net.uk [212.58.244.68] with 32 bytes of data:
Reply from 212.58.244.68: bytes=32 time=10ms TTL=50
Reply from 212.58.244.68: bytes=32 time=11ms TTL=50
Reply from 212.58.244.68: bytes=32 time=9ms TTL=50
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.58.244.68:
Packets: Sent = 106, Received = 86, Lost = 20 (18% loss),
Minimum = 9ms, Maximum = 11ms, Average = 9ms
Control-C
^C
C:\Users\Stu>
