Message 1 of 11
Wednesday morning before 09:00 and no engineer till next Monday
This morning at 08:30 my infinity 2 died, no dsl light but line works.
Called them after doing the normal checks but they say an engineer is needed and next Monday is the earliest.
No other bt Wi-Fi in range so on my mobile.
Such a long wait for an engineer 😞
10 REPLIES 10
Message 2 of 11
Re: Wednesday morning before 09:00 and no engineer till next Monday
Its three working days for residential faults.
Thursday
Friday
Monday
Message 3 of 11
I don't think I can post a screen dump but at the BT site it says I have an open fault but when you open the page there is no fault date, fault number or anything.
I hope the openreach guy has more info than I have received.
Distinguished Guru
Message 4 of 11
Have you tried a factory reset of the hub?
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
Message 5 of 11
My HH5 and Openreach modem both report no dsl 😞
Distinguished Guru
Message 6 of 11
Fair enough 😉
Message 7 of 11
Screenshot_2015-02-27-10-21-59.jpgDetails of my fault.
Is a normal problem with BT?
Message 8 of 11
Well an engineer did come at about 11:40, tested my home end and my modem which were all okay.
He then went to the cabinet and it seems the fault was at that end.
All tests past but at the moment my speed test results are even slower than before.
I assume the circuit is back in training mode?
Distinguished Guru
Message 9 of 11
If you're using the HH5 on it's own can you post the Helpdesk info please?
Otherwise can you post the IP Profile?
Message 10 of 11
My speed seems to be much the same as before now except my HH5 seems to keep doing the same command every 30 mins
Under log type TRO69 I am getting this...
11:01:43, 04 Mar.(61428.980000) CWMP: Set Parameter by TR069 Success
11:01:22, 04 Mar.(61407.670000) CWMP: Set Parameter by TR069 Success
11:01:20, 04 Mar.(61405.950000) CWMP: Set Parameter by TR069 Success
11:00:55, 04 Mar.(61380.640000) CWMP: Set Parameter by TR069 Success
10:31:42, 04 Mar.(59627.500000) CWMP: Set Parameter by TR069 Success
10:31:21, 04 Mar.(59606.200000) CWMP: Set Parameter by TR069 Success
10:31:19, 04 Mar.(59604.480000) CWMP: Set Parameter by TR069 Success
10:30:53, 04 Mar.(59578.480000) CWMP: Set Parameter by TR069 Success
10:01:41, 04 Mar.(57826.150000) CWMP: Set Parameter by TR069 Success
10:01:19, 04 Mar.(57804.810000) CWMP: Set Parameter by TR069 Success
10:01:17, 04 Mar.(57802.700000) CWMP: Set Parameter by TR069 Success
10:00:51, 04 Mar.(57776.590000) CWMP: Set Parameter by TR069 Success
09:31:41, 04 Mar.(56026.660000) CWMP: Set Parameter by TR069 Success
09:31:20, 04 Mar.(56005.350000) CWMP: Set Parameter by TR069 Success
09:31:18, 04 Mar.(56003.630000) CWMP: Set Parameter by TR069 Success
09:30:52, 04 Mar.(55978.090000) CWMP: Set Parameter by TR069 Success
09:01:39, 04 Mar.(54224.890000) CWMP: Set Parameter by TR069 Success
09:01:18, 04 Mar.(54203.590000) CWMP: Set Parameter by TR069 Success
09:01:16, 04 Mar.(54201.920000) CWMP: Set Parameter by TR069 Success
09:00:51, 04 Mar.(54176.590000) CWMP: Set Parameter by TR069 Success
08:31:38, 04 Mar.(52424.020000) CWMP: Set Parameter by TR069 Success
08:31:17, 04 Mar.(52402.720000) CWMP: Set Parameter by TR069 Success
08:31:15, 04 Mar.(52401.010000) CWMP: Set Parameter by TR069 Success
08:30:50, 04 Mar.(52375.360000) CWMP: Set Parameter by TR069 Success
08:01:41, 04 Mar.(50627.030000) CWMP: Set Parameter by TR069 Success
08:01:20, 04 Mar.(50605.710000) CWMP: Set Parameter by TR069 Success
08:01:17, 04 Mar.(50602.430000) CWMP: Set Parameter by TR069 Success
08:00:50, 04 Mar.(50575.260000) CWMP: Set Parameter by TR069 Success
07:01:14, 04 Mar.(46999.360000) CWMP: Set Parameter by TR069 Success
07:00:51, 04 Mar.(46976.270000) CWMP: Set Parameter by TR069 Success
06:31:33, 04 Mar.(45218.850000) CWMP: Set Parameter by TR069 Success
06:31:12, 04 Mar.(45197.540000) CWMP: Set Parameter by TR069 Success
06:31:10, 04 Mar.(45195.910000) CWMP: Set Parameter by TR069 Success
06:30:49, 04 Mar.(45174.600000) CWMP: Set Parameter by TR069 Success
06:01:39, 04 Mar.(43424.180000) CWMP: Set Parameter by TR069 Success
06:01:17, 04 Mar.(43402.680000) CWMP: Set Parameter by TR069 Success
06:01:15, 04 Mar.(43400.940000) CWMP: Set Parameter by TR069 Success
06:00:49, 04 Mar.(43374.150000) CWMP: Set Parameter by TR069 Success
05:31:40, 04 Mar.(41625.800000) CWMP: Set Parameter by TR069 Success
05:31:19, 04 Mar.(41604.500000) CWMP: Set Parameter by TR069 Success
05:31:17, 04 Mar.(41602.350000) CWMP: Set Parameter by TR069 Success
05:30:51, 04 Mar.(41576.830000) CWMP: Set Parameter by TR069 Success
05:01:37, 04 Mar.(39822.640000) CWMP: Set Parameter by TR069 Success
05:01:16, 04 Mar.(39801.330000) CWMP: Set Parameter by TR069 Success
05:01:14, 04 Mar.(39799.550000) CWMP: Set Parameter by TR069 Success
05:00:50, 04 Mar.(39776.050000) CWMP: Set Parameter by TR069 Success
04:31:33, 04 Mar.(38018.730000) CWMP: Set Parameter by TR069 Success
04:31:12, 04 Mar.(37997.430000) CWMP: Set Parameter by TR069 Success
04:31:10, 04 Mar.(37995.820000) CWMP: Set Parameter by TR069 Success
04:30:49, 04 Mar.(37974.510000) CWMP: Set Parameter by TR069 Success
04:01:37, 04 Mar.(36222.720000) CWMP: Set Parameter by TR069 Success
04:01:16, 04 Mar.(36201.410000) CWMP: Set Parameter by TR069 Success
04:01:14, 04 Mar.(36199.220000) CWMP: Set Parameter by TR069 Success
04:00:47, 04 Mar.(36172.850000) CWMP: Set Parameter by TR069 Success
03:31:41, 04 Mar.(34426.980000) CWMP: Set Parameter by TR069 Success
03:31:20, 04 Mar.(34405.680000) CWMP: Set Parameter by TR069 Success
03:31:18, 04 Mar.(34403.450000) CWMP: Set Parameter by TR069 Success
03:30:52, 04 Mar.(34377.760000) CWMP: Set Parameter by TR069 Success
There are more but my post would pass the max size limit
Any thoughts please?
