Message 1 of 3
Weird high ping issues 5 minutes after restarting router
I have a BT homehub and around 20mbps internet.
My internet is really **bleep**ty atm, but it doesnt make much sense, if i restart my router my internet is good for 5 - 10 minutes until it is horribly slow.
I usually play games online, i go from 20 ping to 200 ping which is unplayable but my download speeds remain the same.
I've tried everything from changing the channel, messing around with the router settings, turning off all firewalls. It's been happening for a couple of days now and its really starting to annoy me.
Anyone had a similar issue or knows how to fix it?
the weird thing is if i go to speedtest it shows my ping as 15 - 20 (pingtest shows it has 300+), although this is not true for any other website (i have tried pinging lots of different websites and servers and doing trace routes).
please help, i'm about ready to throw my home hub out the window and see if i can build a better one with things i can find on the floor.
2 REPLIES 2
Message 2 of 3
Re: Weird high ping issues 5 minutes after restarting router
here are the first page of logs:
Time and date Message
15:39:42, 21 Jul. ( 4793.220000) Admin login successful by 192.168.1.165 on HTTP
15:39:07, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61181-​>38.108.170.56:443 on ppp0)
15:38:46, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 208.117.250.121:443-​>86.153.119.32:50625 on ppp0)
15:37:11, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61179-​>38.108.170.56:443 on ppp0)
15:35:18, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61158-​>38.108.170.56:443 on ppp0)
15:34:04, 21 Jul. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 129.82.138.44-​>86.153.119.32 on ppp0)
15:33:50, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 213.120.157.67:80-​>86.153.119.32:50507 on ppp0)
15:33:23, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61157-​>38.108.170.56:443 on ppp0)
15:32:15, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 2.22.79.139:443-​>86.153.119.32:50426 on ppp0)
15:31:15, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61136-​>38.108.170.56:443 on ppp0)
15:31:04, 21 Jul. BLOCKED 1 more packets (because of Packet invalid in connection)
15:31:04, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 23.63.98.43:443-​>86.153.119.32:50356 on ppp0)
15:29:32, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 72.246.184.22:80-​>86.153.119.32:61138 on ppp0)
15:29:32, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 217.212.238.143:80-​>86.153.119.32:61137 on ppp0)
15:29:17, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61135-​>38.108.170.56:443 on ppp0)
15:28:38, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 46.19.168.101:443-​>86.153.119.32:50251 on ppp0)
15:27:24, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61134-​>38.108.170.56:443 on ppp0)
15:25:31, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61133-​>38.108.171.225:443 on ppp0)
15:25:21, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61132-​>38.108.170.254:443 on ppp0)
15:25:20, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61131-​>38.108.171.219:443 on ppp0)
15:25:17, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61129-​>38.108.171.29:443 on ppp0)
15:25:16, 21 Jul. BLOCKED 1 more packets (because of Packet invalid in connection)
15:25:15, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61127-​>38.108.170.226:443 on ppp0)
15:25:14, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61126-​>38.108.170.254:443 on ppp0)
15:25:13, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61110-​>38.108.170.56:443 on ppp0)
15:23:20, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61105-​>38.108.170.56:443 on ppp0)
15:21:57, 21 Jul. ( 3728.420000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>5353, internal ports: 5353, internal client: 192.168.1.166
15:19:35, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61072-​>38.108.170.56:443 on ppp0)
15:18:58, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.193.61:443-​>86.153.119.32:50119 on ppp0)
15:18:42, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.194.246:443-​>86.153.119.32:50093 on ppp0)
15:17:41, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61071-​>38.108.170.56:443 on ppp0)
15:16:50, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 185.24.98.182:80-​>86.153.119.32:50010 on ppp0)
15:16:48, 21 Jul. BLOCKED 4 more packets (because of Packet invalid in connection)
15:16:47, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 185.24.98.182:80-​>86.153.119.32:50005 on ppp0)
15:16:47, 21 Jul. BLOCKED 2 more packets (because of Packet invalid in connection)
15:16:45, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 185.24.98.182:80-​>86.153.119.32:50005 on ppp0)
15:16:20, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 80.249.99.126:80-​>86.153.119.32:49974 on ppp0)
15:16:18, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.246.85:443-​>86.153.119.32:49981 on ppp0)
15:15:45, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61054-​>38.108.170.56:443 on ppp0)
15:13:45, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61051-​>38.108.170.56:443 on ppp0)
15:11:47, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61050-​>38.108.170.56:443 on ppp0)
15:09:47, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61036-​>38.108.170.56:443 on ppp0)
15:07:47, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61034-​>38.108.170.56:443 on ppp0)
15:07:35, 21 Jul. IN: BLOCK [16] Remote administration (TCP 1.163.4.137:12200-​>86.153.119.32:80 on ppp0)
15:05:46, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61013-​>38.108.170.56:443 on ppp0)
15:03:44, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61012-​>38.108.170.56:443 on ppp0)
15:01:45, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61005-​>38.108.170.56:443 on ppp0)
14:59:39, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60993-​>38.108.170.56:443 on ppp0)
14:58:39, 21 Jul. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19-​>86.153.119.32 on ppp0)
14:57:32, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60990-​>38.108.170.56:443 on ppp0)
14:56:38, 21 Jul. BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:38, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:56:35, 21 Jul. BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:34, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:56:32, 21 Jul. BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:32, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:55:48, 21 Jul. IN: BLOCK [16] Remote administration (TCP 50.116.15.188:57216-​>86.153.119.32:8080 on ppp0)
14:55:28, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60975-​>38.108.170.56:443 on ppp0)
14:54:40, 21 Jul. ( 2091.960000) Admin login successful by 192.168.1.165 on HTTP
14:54:12, 21 Jul. ( 2064.030000) New GUI session from IP 192.168.1.165
14:53:07, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60974-​>38.108.170.254:443 on ppp0)
14:53:04, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60972-​>38.108.170.56:443 on ppp0)
14:50:57, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60955-​>38.108.170.56:443 on ppp0)
14:48:52, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60952-​>38.108.170.56:443 on ppp0)
14:47:53, 21 Jul. IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98-​>86.153.119.32 on ppp0)
14:47:22, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 95.100.244.208:443-​>86.153.119.32:49637 on ppp0)
14:45:32, 21 Jul. IN: BLOCK [16] Remote administration (TCP 173.230.156.31:15369-​>86.153.119.32:80 on ppp0)
14:45:00, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60938-​>38.108.170.56:443 on ppp0)
14:43:03, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60933-​>38.108.170.56:443 on ppp0)
14:41:02, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60932-​>38.108.170.254:443 on ppp0)
14:41:01, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60931-​>38.108.170.254:443 on ppp0)
14:38:36, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60910-​>38.108.170.254:443 on ppp0)
14:37:35, 21 Jul. OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60907-​>38.108.170.254:443 on ppp0)
14:29:31, 21 Jul. IN: BLOCK [9] Packet invalid in connection (TCP 72.246.184.22:80-​>86.153.119.32:60863 on ppp0)
14:26:28, 21 Jul. IN: BLOCK [16] Remote administration (TCP 111.241.33.59:12200-​>86.153.119.32:80 on ppp0)
14:24:43, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:24:41, 21 Jul. IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:24:07, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:24:06, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:23:58, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:23:42, 21 Jul. IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:23:22, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:23:21, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:23:13, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:22:41, 21 Jul. IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:22:37, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:22:36, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:22:28, 21 Jul. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:22:22, 21 Jul. IN: BLOCK [15] Default policy (TCP 66.193.112.93:443-​>86.153.119.32:39324 on ppp0)
14:22:22, 21 Jul. ( 153.540000) CWMP: session completed successfully
14:22:22, 21 Jul. ( 153.320000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
14:22:18, 21 Jul. ( 149.860000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:22:18, 21 Jul. ( 149.850000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
14:22:12, 21 Jul. IN: BLOCK [15] Default policy (TCP 54.243.220.57:80-​>86.153.119.32:49616 on ppp0)
14:21:58, 21 Jul. BLOCKED 1 more packets (because of Default policy)
14:21:57, 21 Jul. IN: BLOCK [15] Default policy (TCP 213.120.161.186:80-​>86.153.119.32:49608 on ppp0)
14:21:54, 21 Jul. IN: BLOCK [15] Default policy (TCP 213.248.117.222:48726-​>86.153.119.32:49601 on ppp0)
14:21:55, 21 Jul. ( 127.040000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>5353, internal ports: 5353, internal client: 192.168.1.166
14:21:54, 21 Jul. BLOCKED 2 more packets (because of Default policy)
14:21:53, 21 Jul. IN: BLOCK [15] Default policy (UDP 72.246.184.22:3478-​>86.153.119.32:54869 on ppp0)
Message 3 of 3
15:16:48, 21 Jul.BLOCKED 4 more packets (because of Packet invalid in connection)
15:16:47, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 185.24.98.182:80-​>86.153.119.32:50005 on ppp0)
15:16:47, 21 Jul.BLOCKED 2 more packets (because of Packet invalid in connection)
15:16:45, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 185.24.98.182:80-​>86.153.119.32:50005 on ppp0)
15:16:20, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 80.249.99.126:80-​>86.153.119.32:49974 on ppp0)
15:16:18, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 95.100.246.85:443-​>86.153.119.32:49981 on ppp0)
15:15:45, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61054-​>38.108.170.56:443 on ppp0)
15:13:45, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61051-​>38.108.170.56:443 on ppp0)
15:11:47, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61050-​>38.108.170.56:443 on ppp0)
15:09:47, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61036-​>38.108.170.56:443 on ppp0)
15:07:47, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61034-​>38.108.170.56:443 on ppp0)
15:07:35, 21 Jul.IN: BLOCK [16] Remote administration (TCP 1.163.4.137:12200-​>86.153.119.32:80 on ppp0)
15:05:46, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61013-​>38.108.170.56:443 on ppp0)
15:03:44, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61012-​>38.108.170.56:443 on ppp0)
15:01:45, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:61005-​>38.108.170.56:443 on ppp0)
14:59:39, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60993-​>38.108.170.56:443 on ppp0)
14:58:39, 21 Jul.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 203.178.148.19-​>86.153.119.32 on ppp0)
14:57:32, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60990-​>38.108.170.56:443 on ppp0)
14:56:38, 21 Jul.BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:38, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:56:35, 21 Jul.BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:34, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:56:32, 21 Jul.BLOCKED 1 more packets (because of Packet invalid in connection)
14:56:32, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 54.243.220.57:80-​>86.153.119.32:49811 on ppp0)
14:55:48, 21 Jul.IN: BLOCK [16] Remote administration (TCP 50.116.15.188:57216-​>86.153.119.32:8080 on ppp0)
14:55:28, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60975-​>38.108.170.56:443 on ppp0)
14:54:40, 21 Jul.( 2091.960000) Admin login successful by 192.168.1.165 on HTTP
14:54:12, 21 Jul.( 2064.030000) New GUI session from IP 192.168.1.165
14:53:07, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60974-​>38.108.170.254:443 on ppp0)
14:53:04, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60972-​>38.108.170.56:443 on ppp0)
14:50:57, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60955-​>38.108.170.56:443 on ppp0)
14:48:52, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60952-​>38.108.170.56:443 on ppp0)
14:47:53, 21 Jul.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 128.9.168.98-​>86.153.119.32 on ppp0)
14:47:22, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 95.100.244.208:443-​>86.153.119.32:49637 on ppp0)
14:45:32, 21 Jul.IN: BLOCK [16] Remote administration (TCP 173.230.156.31:15369-​>86.153.119.32:80 on ppp0)
14:45:00, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60938-​>38.108.170.56:443 on ppp0)
14:43:03, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60933-​>38.108.170.56:443 on ppp0)
14:41:02, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60932-​>38.108.170.254:443 on ppp0)
14:41:01, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60931-​>38.108.170.254:443 on ppp0)
14:38:36, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60910-​>38.108.170.254:443 on ppp0)
14:37:35, 21 Jul.OUT: BLOCK [9] Packet invalid in connection (TCP 192.168.1.166:60907-​>38.108.170.254:443 on ppp0)
14:29:31, 21 Jul.IN: BLOCK [9] Packet invalid in connection (TCP 72.246.184.22:80-​>86.153.119.32:60863 on ppp0)
14:26:28, 21 Jul.IN: BLOCK [16] Remote administration (TCP 111.241.33.59:12200-​>86.153.119.32:80 on ppp0)
14:24:43, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:24:41, 21 Jul.IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:24:07, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:24:06, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:23:58, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:23:42, 21 Jul.IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:23:22, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:23:21, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:23:13, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:22:41, 21 Jul.IN: BLOCK [53] Defragmentation failed (Unknown protocol: 0)
14:22:37, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54127-​>173.194.41.164:443 on ppp0)
14:22:36, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54126-​>74.125.230.70:443 on ppp0)
14:22:28, 21 Jul.OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.168:54120-​>74.125.230.83:443 on ppp0)
14:22:22, 21 Jul.IN: BLOCK [15] Default policy (TCP 66.193.112.93:443-​>86.153.119.32:39324 on ppp0)
14:22:22, 21 Jul.( 153.540000) CWMP: session completed successfully
14:22:22, 21 Jul.( 153.320000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
14:22:18, 21 Jul.( 149.860000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:22:18, 21 Jul.( 149.850000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
14:22:12, 21 Jul.IN: BLOCK [15] Default policy (TCP 54.243.220.57:80-​>86.153.119.32:49616 on ppp0)
14:21:58, 21 Jul.BLOCKED 1 more packets (because of Default policy)
14:21:57, 21 Jul.IN: BLOCK [15] Default policy (TCP 213.120.161.186:80-​>86.153.119.32:49608 on ppp0)
14:21:54, 21 Jul.IN: BLOCK [15] Default policy (TCP 213.248.117.222:48726-​>86.153.119.32:49601 on ppp0)
14:21:55, 21 Jul.( 127.040000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>5353, internal ports: 5353, internal client: 192.168.1.166
14:21:54, 21 Jul.BLOCKED 2 more packets (because of Default policy)
14:21:53, 21 Jul.IN: BLOCK [15] Default policy (UDP 72.246.184.22:3478-​>86.153.119.32:54869 on ppp0)
