Message 11 of 25
Re: Weird throughput 'problems'
There could be 100 different reasons why down to network routing/those particular servers etc.
Message 12 of 25
you need an absolute minimum of 3 db preferable 6db to guarantee stability squeezing the last bit of connection speed out of a line like yours is not needed you will hardly notice any difference
Recognised Expert
Message 13 of 25
I understand that fact John.
What I'll do if I have the problem when I get home is reset my SNR slider to 100% (Which should reset the Noise Margin to ~6dB hopefully - The default SNR) and see if the problem still occurs.
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Recognised Expert
Message 14 of 25
I got home tonight and wanted to get both problems sorted so what I did was replace the cable out of the XF-1e with another (BS6312 to RJ11) and plugged it into the Test Socket.
Now I didn't touch any of my SNR settings at all and I was quite amazed by the results when it synced up:
                              Down        Up
Connection Speed: 24276 kbps 1211 kbps
Line Attenuation: 16.5 db 6.4 db
Noise Margin: 1.1 db 6.2 db
Believe it or not while I was writing the part above, my connection must have received a massive spike in interference (At 21:33) and I managed to catch the SNR being reported at -1.0 and about 50 CRC Errors per second (I observed the connection getting around 157 CRC errors an hour after I fiddled around with the Microfilter before the spike).
What on earth could cause a drop of 2dB within 2 seconds!?
Obviously my router has resynced at a lower rate. As it is now:
                              Down        Up
Connection Speed: 22874 kbps 1219 kbps
Noise Margin: 1.0 db 5.8 db
The throughput for the ThinkBroadband Files was stable around 1513KB/s before the spike so could it be a peering issue?
Other downloads from Apple and Rapidshare were downloading at 2.4-2.5MB/s (Downloaded Seperately).
Message 15 of 25
at that very low noise margin any thing could cause a spike like that If you want to avoid that then you MUST increase the noise margin you are not going to lose out that much speed wise It is a matter of speed or stability only you can choose but i know what i would do
Recognised Expert
Message 16 of 25
Thanks for the reply John.
Sometime today, my router resynced with a 4.0dB Noise Margin at 21,392Kbps :).
I left router stats going and noticed some sudden ups and downs throughout today. The SNR was stable until about 09:10 today when it rose to about 2.8dB:
Then at 11:10 the SNR dropped to 0 and the line resynced:
And then at 12:51 the SNR dropped to 0 and then rose to 4dB (Along with a lower sync):
What could possibly be causing the SNR drops/rises? I'm guessing the rise at 09:10 was street lighting being switched off, but what could possibly be causing the others?
When I get home, I'll test the throughput speeds on files from ThinkBroadband and see if they are still a problem because the line has minimal errors with its low sync now.
Message 17 of 25
your SNR is to low that is the cause it needs to be at 6db to give you a chance of a stable connection adsl2+ is very noise aggressive
Message 18 of 25
I would watch again tomorrow and see if the drops occur at about the same time suggesting there is something switching on/off causing the interference and not just random spikes/troughs
Message 19 of 25
john46 I don't think noise margin need to be set at 6db but if it happens again at same time it's a matter of trying to identify what is causing the drop.  noise margin is ok if you can eliminate the interference
Message 20 of 25
true I suggested it because of some earlier very low noise levels with the posters very high connection speed the increase of noise margin would hardly be noticed
