N0STIE
Message 1 of 14
What DLM profile do BT use?
Hi,
Anyone knows what DLM profile BT uses? Stable, Standard or Speed?
I am wondering, because I have been interleaved recently and now getting very low ES rate (5-6 per 24hours) and don't seem to get fast path back with total uptime of about a week now since connected HG612 to monitor my stats.
13 REPLIES 13
pippincp
Message 2 of 14
Re: What DLM profile do BT use?
See HERE .
Stable (at the bottom)
licquorice
Message 3 of 14
Nope, think you will find it is 'Speed'
N0STIE
Message 4 of 14
Are you sure BT uses stable profile?
If so, the maximum allowed errors are 30/hour and 1440 per 24 hours. This can't be right as I used to get over 40 ES/h on fastpath and been like that for more than a year.
pippincp
Message 5 of 14
My bad, it is speed. Thanks for the correction @licquorice
N0STIE
Message 6 of 14
Thanks for reply guys.
How many drops does speed profile allow and what is the ES threshold?
licquorice
Message 7 of 14
I'm sure you've been through all this over on Kitz. But here's the figures.
N0STIE
Message 8 of 14
@licquorice
Thanks,
Yes I've been through this on kitz but no one ever clearly said what DLM profile BT use.
First time seeing this table, thanks for that!
Webby
Message 9 of 14
I'm also pretty sure it's speed
N0STIE
Message 10 of 14
@Webby
Thanks for confirming.
On the other hand what could have caused the maximum supported speed by my line to drop quite a bit? It used to be around 52-42Mb (Range A Clean) down and 11-8 Mb up. Range B has dropped as well. Although my HG612 OR modem still showing same attainable speed with same SnR for both DS and US. I know when interleaved attainable is higher than it should be but still. Possibly crosstalk?
