Message 1 of 9
What Is Maximum Data Rate ?
On speedtest.net i get 78MBps
8 REPLIES 8
Message 2 of 9
Re: What Is Maximum Data Rate ?
It's the theoretical maximum your line can deliver in ideal conditions. There is a bug in the hub that often shows the max as being lower than actual.
Message 3 of 9
The reason you data rate is well above max attainable is due to your very low noise margin of 0.6db be really surprised if your connection will remain stable
Message 4 of 9
It’s been synced at 80mb for nearly two days with no dropouts
Message 5 of 9
well just need to hope it continues but I would not like my noise margin to be 0.6db
Message 6 of 9
Fair enough. Thanks 😄
What is noise margin, and what is a normal range ?
Its now 5.6db/0.5db
Message 7 of 9
normal down is about 6db or could be as low as 3db if G.INP has been activated on your conenction   it can be higher than 6db in certain circumstances - for exmple mine is 9.1db because my connection is restricted  to 80mb but my attainable is higher
Message 8 of 9
Noise margin:
5.8 dB / 3.2 dB
as expected my sync speed is back at 69mb 😞 dont know why, it was running perfect @ 80
Message 9 of 9
Because your noise margin was exceptionally low at 0.6db and as I expected your connection has reset with a more realistic noise margin
