So most ISPs except Virgin offer upto 80MB FTTC, when will this increase ( if at all ) ?
Also, the DSLAM down the road from me has a loose cabinet door and swings open. Openreach are usually around this area, should I tell someone ?
notify openreach https://www.openreach.co.uk/orpg/home/submitFeedbackLoggedInUser.do
if you cabinet is G.Fast enabled, you can get faster than 80meg... I'm on G.Fast and get 130 > 140meg on BT
@NigelB72wrote:if you cabinet is G.Fast enabled, you can get faster than 80meg... I'm on G.Fast and get 130 > 140meg on BT
Only if you are within 300mts of the cab.
of which i am 🙂
@NigelB72 wrote:
of which i am 🙂
Obviously other wise you would not be getting it!😉
