Nick44
Newbie
Message 1 of 5
What Speed could i get & what are the errors
Hi Everyone.
   I have just joined B.T & yesterday was my last day of the 10 day period.
   Bin looking at my speed it hasnt gone up alot but i keep getting all these errors on the hub info so i would like to ask what are the errors please & does the speed look about right for me thanks Nick..
 Short time for connection as B.T reset the Hub its a v3.0a
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 06:08:58
Downstream:4.931 Mbps
Upstream:1011 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.5 dB / 5.8 dB
Line attenuation (Down/Up):46.4 dB / 27.7 dB
Output power (Down/Up):18.5 dBm / 12.6 dBm
FEC Events (Down/Up):126408871 / 3607
CRC Events (Down/Up):102820 / 739
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):91458 / 730
Error Seconds (Local/Remote):32083 / 501
4 REPLIES 4
NilSatisOptimum
Recognised Expert
Message 2 of 5
Re: What Speed could i get & what are the errors
Just enter your down attenuation here- http://www.kitz.co.uk/adsl/max_speed_calc.php  there are things you can do to reduce errors like connecting to the master socket see if there is a difference, checking your wiring and housing of the hub etc. A explanation of errors here-http://www.kitz.co.uk/adsl/linestats_errors.htm
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
Nick44
Newbie
Message 3 of 5
Thanks very much
  It seems there is much noise on the line . When i moved in there was a rustleing noise but that went but could still be there when i am on not on the phone as i don't use it much i rand the numbers with option 2 as well & just got a hum on my cordless phone..
  How would i go reporting this please thanks..
NilSatisOptimum
Recognised Expert
Message 4 of 5
Noisy line! When making telephone calls, if so this is not good for your broadband, you can check-
Quite line test dial 17070 option 2 and listen - should hear nothing best done with old type analogue phone digital (dect) will do but may have slight hiss If you hear noise- crackling pops etc, report it as a noisy line on your phone, don’t mention broadband, Bt Faults on 151.
Nick44
Newbie
Message 5 of 5
  Just did the test & it sounds like its raining on the line i will report it thank you for the help..
