paulloseby
Message 1 of 5
What broadband cable for Smarthub - help please
I've got my new Smart hub but they say that I need a broadband cable that goes direct from the telephone socket to the broadband socket on the hub.  'Broadband Cable grey ends'.  Can I find what cable I need - no.  Helpline to India was useless as I couldn't understand the chap.  Can anyone please help me by telling me what cable I need and the best place to get one from?
Many thanks
Paul
4 REPLIES 4
imjolly
Message 2 of 5
Re: What broadband cable for Smarthub - help please
the cable is an rj11 modem cable which is the standard cable to connect routers to filter in phone socket or broadband socket on SSFP socket
if you had adsl then it is same cable that conencted your router to socket
paulloseby
Message 3 of 5
Very many thanks for that.  At least I know now.
Kindest regards and I do really appreciate your help
Paul
Bairn666
Message 4 of 5
I need to move my hub. Despite being asked to do so, the engineer didn't leave suffucient cable so I need to but one. So, 64 000 dollar question is, crossover or straight through? Or will either do?
Keith_Beddoe
Message 5 of 5
Either, just use straight through. I assume you mean the Ethernet cable/
