charlienotman91
Message 1 of 5
What cabinet am I connected to and will I be able to get FTTC?
Hello there,
So all around me I see there is new green cabinets getting installed and I'm unsure which one I am connected to so that I may verify if I am going to get it. My postcode is CA24ST,
Thanks for any help!
Charlie.
4 REPLIES 4
john46
Message 2 of 5
Re: What cabinet am I connected to and will I be able to get FTTC?
try these links http://fttc-check.alc.im/
http://www.superfast-openreach.co.uk/where-and-when/ not all cabinets can be enabled or in deed are first time around as there are various phases all dates shown are place holding only and subject to change
Mark039
Message 3 of 5
According to the checker I use, you're connected to cabinet P22.
It indicates that this cabinet is not currently scheduled for upgrade, but it's based on info which is 6 months old now.
Aarong
Guru
Message 4 of 5
Hi and welcome to the forum, on the PCP spreadsheet has no rollout information in regards to your postcode. This is based on 6 months out of date information so things could have changed by now.
Best thing to do is keep an eye on the checker here: https://www.btwholesale.com/includes/adsl/main.html
This has the most recent and up to date information about what is available to you.
Edit: Wow 2 replies already lol!
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
charlienotman91
Message 5 of 5
Ah, bummer. Thanks for the quick replies though guys.
