Sylver123
Expert
Message 1 of 7
What connection have I actually got in MB?
Hello.
I am on BTs 21CN network and on their new profile system and right at this moment I am connected
at sync rate of 5504 kbps and my download speed I see when downloading is 600 KB/s.
6 REPLIES 6
stuartrogerson
Distinguished Guru
Message 2 of 7
Re: What connection have I actually got in MB?
5.5 megs
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Sylver123
Expert
Message 3 of 7
Thanks a lot buddy for the quick response. I thought it would be 5MB or just slightly over but
wasn`t 100% sure as I am not familiar with BTs new profile system etc.
I know on BTs old system, it would still only be 4.5MB.
john46
Message 4 of 7
Your profile is now 88.2% of your connection speed
Sylver123
Expert
Message 5 of 7
Does anybody know of a website or etc that has an explanation of BTs new 88.2% system and
shows the sync rates and IP profile and what the speed it is in MB?
I used to follow the information on the thinkbroadband page below to see what connection I
have but this is no longer valid for the new system.
http://www.thinkbroadband.com/news/2622-another-max-product-update.html
imjolly
Message 6 of 7
Bt 's new profile system is 88.2% of connection speed whereas before there was a table.  I'm sure if you read here then you will find all the information you require http://www.kitz.co.uk/adsl/IPprofile.htm
http://www.kitz.co.uk/adsl/max_speed_calc.php
john46
Message 7 of 7
there is no site that shows the new method simply use a calculator now the easy way
