Message 1 of 8
What could make my hub go Latency type: Fast?
My hub is currently on Fast and I constantly have problems with my Vodafone SureSignal dropping out.
If I went to Interleaved would this help?
The hub was set to Interleaved by  an Openreach engineer some time ago because of noise problems but seems to have reverted to Fast.
7 REPLIES 7
Message 2 of 8
Re: What could make my hub go Latency type: Fast?
can you post the adsl stats from your router please
Message 3 of 8
ADSL Line Status
Connection information
Line state:Connected
Connection time:2 days, 15:13:48
Downstream:3,563 Kbps
Upstream:811 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Fast
Noise margin (Down/Up):5.2 dB / 6.2 dB
Line attenuation (Down/Up):54.0 dB / 32.8 dB
Output power (Down/Up):0.0 dBm / 12.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):4618 / 398
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):9648 / 237
Error Seconds (Local/Remote):0 / 270
 More Details
Message 4 of 8
Your connection has probably changed to fast as the stats look ok with few errors for a connection time 2+ days. Are you using a wireless connection or wired. If wireless have you tried changing the wifi channel?
Message 5 of 8
I use wireless for most things but the connection between the Vodafone SureSignal and the hub is wired.
Message 6 of 8
I suggest you try the forum search feature using
Vodafone SureSignal as the search you may find help with some of the other posts on the subject
Message 7 of 8
Not much point in that there are so many people who have problems with their SureSignal it would take weeks to wade through all the various forum posts.
I'm actually fairly lucky that mine works at all!
I just thought that Interleaved might help improve it.
Message 8 of 8
Your connection is stable so changing to interleaved I dont think will help your current problem
