Message 1 of 5
What happens if the hub disconnects during a recording?
If you're recording an internet stream channel, what happens if your internet disconnects? Do you lose a chunk forever? Is there some sort of redundancy or backup? What's the protocol with this?
As someone whose hub has a habit of going on the blink and booting me offline, I'd like to know my options ahead of time.
4 REPLIES 4
walkerx
Recognised Expert
Message 2 of 5
Re: What happens if the hub disconnects during a recording?
I believe the recording is affected. you could test it by setting a recording of something then disconnecting and see what happens
Distinguished Guru
Message 3 of 5
It fails
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Message 4 of 5
I guess that's when you have to fall back on the 7 day rewind thing
sirjamesp
Message 5 of 5
There isn't much available on catch-up from the internet channels.
