Message 1 of 5
What is a typical 'Ping' value with Infinity?
Hi,
     noticed that someone had said that they were getting a Ping Value of 5ms on their system. I typically get a value of 20ms and was wondering what was 'normal'.
I get this value from using speedtest.net and on the 40/10 Infinity I get Speeds of 37.4/8.20 as I live virtually next to the box.
Thanks,
4 REPLIES 4
Message 2 of 5
Re: What is a typical 'Ping' value with Infinity?
20ms is just fine.
Message 3 of 5
I've seen anything from 5 to 30 depending on the time of day and the destination of the test server.
Message 4 of 5
I normally get aping of between 5 and 18 using speedtest.net
Message 5 of 5
http://www.pingtest.net/result/60915639.png on FTTP.
From ADSL to FTTP i went down about 6-7ms to most sites like google/bbc etc.
C:\>ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data: Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241
Ping statistics for 212.58.241.131:     Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds:     Minimum = 9ms, Maximum = 9ms, Average = 9ms
