Hi,
noticed that someone had said that they were getting a Ping Value of 5ms on their system. I typically get a value of 20ms and was wondering what was 'normal'.
I get this value from using speedtest.net and on the 40/10 Infinity I get Speeds of 37.4/8.20 as I live virtually next to the box.
Thanks,
20ms is just fine.
http://www.pingtest.net/result/60915639.png on FTTP.
From ADSL to FTTP i went down about 6-7ms to most sites like google/bbc etc.
C:\>ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data: Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241 Reply from 212.58.241.131: bytes=32 time=9ms TTL=241
Ping statistics for 212.58.241.131: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 9ms, Maximum = 9ms, Average = 9ms
