Message 11 of 18
Re: What is better?
I currently have a home hub 2 on ADSL 2 up to 8mb. the main reason I was wanting to upgrade was to get better wirelss range while having a stable connection overall.
___________________________
Message 12 of 18
Re: What is better?
Also I jsut don't like the home hub 2. the firmware is buggy.
Recognised Expert
Message 13 of 18
Re: What is better?
So is this home hub 3.0 really better? Does it give better sync speeds, wireless range than a HH2 or 2WIRE 7000HGV?
Message 14 of 18
Re: What is better?
I was wondering all that too 😕
Recognised Expert
Message 15 of 18
Re: What is better?
I am hoping the HH3, will give brilliant sync speeds, along with my ADSL nation faceplate, and shielded RJ11 cable, without those, my connection would be unbeleivably unstable, I reverted it back to the old sockets last weekend and 3 drop outs within 1 minute, now with all that extra equiptments and a 7000HGV (which is the only router that works properly on my line) I get maybe 1 dropout every 3-4 days.
Message 16 of 18
Re: What is better?
My connection proberly resyncs every 30 to 40 days (I don't know if it would stay on longer than that becuase I had to turn it off ha ha) but I was just interested to know if it is better at all that.
Recognised Expert
Message 17 of 18
Re: What is better?
These are my modem stats
Modem Type: Built in modem - ADSL
DSL Line (Wire Pair): Line 1 (inner pair)
Current DSL Connection:
Down Up
Rate: 896 kbs 448 kbs
Max Rate: 896 kbs 476 kbs
Noise Margin: 6.0 dB 7.0 dB
Attenuation: 68.7 dB 31.5 dB
Output Power: 16.3 dBm 11.9 dBm
Protocol: G.DMT Annex A
Channel: Interleaved
DSLAM Vendor Information Country: {3840} Vendor: {ALCB} Specific: {0 }
ATM PVC: 0/38
Pretty poor considering on a rubbish Hawei they were over 1MB until a BT engineer changed the line routing dropped by a half. 😞
Message 18 of 18
Re: What is better?
my stats are:
good, so I duno why I was asking about the sync rate being better with the hime hub 2 I was just wondering ha ha. I think I will ring BT tomorrow and ask for one Smiley Tongue
Connection Information
Line stateConnected
Connection time0 days, 14:18:08
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)11.8 dB / 25.0 dB
Line attenuation (Down/Up)6.6 dB / 2.5 dB
Output power (Down/Up)13.5 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)1415 / 27
CRC Errors (Down/Up)53 / 14
HEC Errors (Down/Up)535 / 9
Error Seconds (Local/Remote)37 / 8
