Expert
Message 1 of 7
What is the fastest my line can go ?
IS 53mb the quickest my line supports ? Thanks
6 REPLIES 6
Message 2 of 7
Re: What is the fastest my line can go ?
no it should be able to support up to 79 Mbps depending on your lines condition and the package you are on
Message 3 of 7
All depends. Your distance from the PCP, type of cable and cable guage, type of DSLAM, your internal wiring/setup, how many other subscribers are on the same DSLAM, what Modem/Router you use.
Message 4 of 7
It should be somewhere between 59 and 79mbps though, in an ideal world.
Expert
Message 5 of 7
Thanks guys, just don't know why my router says 55mb down, but 18mb up. i thought 18mb up would be infinity 2 ?
Message 6 of 7
You may be on a banded profile, due to instability?
Can you post the hub stats?
Message 7 of 7
