AndrewKing
Message 1 of 15
What is this odd connection?
Can anyone shed any light on what this wierd connection is on my HH5 DHCP table?
I've no idea what the device is at all or why it has an IP address outside the tables range : /
14 REPLIES 14
ray_dorset
Distinguished Guru
Message 2 of 15
Re: What is this odd connection?
Can you post the address? I need something to go on.
If not, I'll try again 🙂
AndrewKing
Message 3 of 15
Yeah I just put it in, for some reason the image didn't go in first time.
ray_dorset
Distinguished Guru
Message 4 of 15
That's someone's HTC android phone
AndrewKing
Message 5 of 15
How is it getting access to the router outside of the IP range?
licquorice
Message 6 of 15
Its using your BT FON, which uses a different subnet
AndrewKing
Message 7 of 15
Now there is two of them : /
They only show up on the DCHP table, not on the front page of the router config page under the "Devices currently connected to your BT Home Hub".
AndrewKing
Message 8 of 15
Wierd since I opted out of BTFon over a year ago.
licquorice
Message 9 of 15
Obviously unsuccesfully.
Edit: if you trawl through the forum you will see problems with turning off the 5Ghz FON signal.
AndrewKing
Message 10 of 15
Checked my status:
Your BT Wi-fi account details
BT broadband option:BT Infinity Option 2
BT Wi-fi community status:Opted Out
But on the HH front page:
BT Wi-fi Status:Active
Any idea who I should contact about it?
