CuReLeSsVeNoM
Message 1 of 19
What's Happening??
Ok so been connected now for a couple of months and must say I love the speed of Infinity and couldnt live without it now. I have been looking at my stats to see how things are going and since I was first connected with these stats:
Data rate: 19999/79995
Maximum data rate: 39539/115993
Noise margin: 24.3/16.6
Line attenuation: 0.0/12.5
Signal attenuation: 0.0/12.6
I'm now getting:
Data rate: 19999 / 79995
Maximum data rate: 28446 / 87452
Noise margin: 14.5 / 7.4
Line attenuation: 0.0 / 12.4
Signal attenuation: 0.0 / 12.5
As you can see my Maximum data rate has dropped by over 28000 with my noise margin dropping with it too. I was the first person connected when our cab went live. Although I'm still connected at 79995 which I assume is the max possible???? I'm just concerned that shortly I'll start losing my sync speed.
Any ideas if this is a problem on the line or simply congestion/interference in the cab?
Also is 79995 the max possible on Infinity 2?
Regards,
Todd
18 REPLIES 18
legitimise_sailing
Distinguished Expert
Message 2 of 19
Re: What's Happening??
As more people go live on your cab, the noise increases and so your noise margin falls
To say thanks for a helpful answer, please click the white star
gg30340
Message 3 of 19
When you first get Infinity it starts of with a high speed and during the "training" period, when your speeds may fluctuate up and down, DLM (Dynamic Line Management) works out what is the fastest stable connection that your line can support. Once this has been established it is often lower than the initial speed you started on. 79995 is the max on Infiity2.
CuReLeSsVeNoM
Message 4 of 19
Is there a way to test if i'm on Fastpath?
gg30340
Message 5 of 19
Why?
CuReLeSsVeNoM
Message 6 of 19
Why do you think?
gg30340
Message 7 of 19
I have no idea why you want to know that's why I asked!
For your info as far as I am aware there is no way of telling with your BT Homehub. DLM could put you on it one day but not the next. An indication is by doing a ping to bbc.co.uk and if it's below 10ms then you will be on fastpath.
con_dorleone
Message 8 of 19
Ridiculously daft question - but is there anyway to find out how many connections there are in a cabinet? Probably not.
CuReLeSsVeNoM
Message 9 of 19
gg30340 FYI most people will ask about being on fastpath if they are a "Gamer"... Although I am no serious gamer I do believe that fastpath is better for ping times.
I found your question to be more of a "dig" at me for even asking the question. Like it's not allowed. However, I hope I have gave you a little enlightenment on the subject.
I was previously with BE* for my broadband and "Gamer Mode" was an option via the members area so I am keen to try and find out what I'm on. Thanks for the ping tip to bbc.. I'll give that a try 🙂
gg30340
Message 10 of 19
It was not a dig at you, you can ask as many questions as you like but apparently I can't. If I had known the reason I would not have asked. I am not a gamer so thank you for enlightening me.
