DelSP10
Message 11 of 13
Re: What's the point in service status checking?
@sps
When I check status pages, I look at suurounding area.................. might not be local issue for me but, has impact on my connection.
I look at UK net as a motorway.
If there is main road closed then traffic is diverted, which in turn causes a slow down/bottleneck
A1944
Expert
Message 12 of 13
sps:
I don't think you have stated whether you are using WiFi or not.
If you are, have you made sure that your problem is not caused by intermittent interference from other routers near to you?
RichRolls
Message 13 of 13
To see if it is just you, try running:
http://www.downforeveryoneorjustme.com/
Hope this helps
Rich
If you found this information helpful, please click the star to the left of this post. If the reply answers your question then please mark as ’Mark as Accepted Solution’
