andyrossitter
Message 1 of 3
What should be my best speed, unable to get infinity even though FTTC is live in my area
I live on a new build estate where the local exchange has had fttc just released, using the bt speed checker i am led to believe that becuase the line will only support 12.2mbps they will not install infinity, I am on ADSl Max with a broadband line spped of 1.5Mbps with ADSL2+ due by end of Jan next year with a potential of 2Mbps, bt home hub 2 is connected to master socket by cable and not wireless and stats are
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 02:36:36
Downstream2,368 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)5.1 dB / 18.0 dB
Line attenuation (Down/Up)54.9 dB / 31.5 dB
Output power (Down/Up)4.0 dBm / 1.4 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)7621 / 5
CRC Errors (Down/Up)10351 / 8
HEC Errors (Down/Up)23834 / 2
Error Seconds (Local/Remote)2908 / 8
FAQ
Results Image not loaded
Download  Speed
1579 Kbps
0 Kbps2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 1579 Kbps
 For your connection, the acceptable range of speeds is 400-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2368 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 1750 Kbps
is this the best i can expect?
Can my spped improve if more people move onto infinity and why won't bt allow me infinity despite it being loads faster than my current?
2 REPLIES 2
hamish72
Recognised Expert
Message 2 of 3
Re: What should be my best speed, unable to get infinity even though FTTC is live in my area
According to
http://www.kitz.co.uk/adsl/max_speed_calc.php
you should make around 3900 kbs
it is approximate but usually fairly close
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
kirwin
Message 3 of 3
I have the same problem and my current speed is only 120Kbps and my estimated speed for infinity is 13Mbps which with infinity will be much more but for me 13Mbps is a massive improvement and they will not allow use to get it is a disgrace.
