Midgetgem1973
Message 1 of 7
What speed could I expect?
When I go on to this site http://fttc-check.alc.im/search/BB88BN it says uplift 11.47, I'm currently connect at 11mbps on adsl 2+ so what can I expect on fibre once my cabinet goes live?
6 REPLIES 6
Message 2 of 7
Re: What speed could I expect?
it would suggest a maximum possible connection
this checker will give you more accurate information
http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
just check the speeds for FTTC
Midgetgem1973
Message 3 of 7
It doesn't show anything yet as the FTTC cabinet has only just been switched on and we are waiting for BT to commision it. It seems to be taking forever. But as I thought yes I should get maximum speed. Cabinet is not that far away so that's good. Just keep checking every day to see if I can order yet x
Message 4 of 7
By switched on can you hear the fans if you stand beside the cabinet? If nothing then not yet ready
Midgetgem1973
Message 5 of 7
I was driving passed last week and a chap was at the FTTC cabinet and I stopped and asked and he said he has switched it on and it's all ready to go, just waiting on BT now. I may go and have a listen when I next go out
Message 6 of 7
As i have said on other posts it took a year after installation before it was available but once the fans were running it was only about 7 days to activation
Midgetgem1973
Message 7 of 7
I've just checked again, in the wholesale website and it's now changed to show what I should get and it's available on the 30th June. Will keep checking each day to see if I can order as I know sometimes the dates can change 🙂
