jdowning640
Message 1 of 8
What speed should I be getting?
I got an engineer out today because of the noise on the line and he was very good. He replaced the cable from the pole to my premises and my sync speed has went up from around 2000Kbps odd to around 7000Kbps.
Whenever I do speedtests though, I get around 3Mbps, shouldn't it be higher than this?
Here's my stats, and also... if I did ever get up to 8Mbps, would I ever be able to get Infinity? My cabinet and exchange are enabled (definitely).
So my speedtests come up at about 3Mbps, what can I do to get it higher if the sync speed is near 7400Kbps
7 REPLIES 7
MrP
Message 2 of 8
Re: What speed should I be getting?
The speed you get is very much dependent on the length of the wire / the distance from the exchange... how far are you from the exchange?
jdowning640
Message 3 of 8
I am around 2 miles from the exchange and 1.5 miles from cabinet.
daleski75
Message 4 of 8
There are a lot of factors which can cause slow speed. Best thing to do is the following.
1. Post your HH2 stats along with uptime
2. Post results from www.speedtester.bt.com
3. Post results from http://www.samknows.com/broadband/exchange_search
Once we have all 3 we can help you determine the speed you 'should' get.
One thing to note is even if your sync rate is 7400 but your profile is 3000 then your speed will always be 3000.
jdowning640
Message 5 of 8
I don't have a Home Hub 2 - I use a Linksys WAG354G
1)
 Up
   DSL Modulation Mode:  GDMT
   DSL Path Mode:  INTERLEAVED
   Downstream Rate:  7712 Kbps
   Upstream Rate:  448 Kbps
   Downstream Margin:  9 db
   Upstream Margin:  25 db
   Downstream Line Attenuation:  36
   Upstream Line Attenuation:  20
   Downstream Transmit Power:  0
   Upstream Transmit Power:  0
PVC Connection
   Encapsulation:  RFC 2364 PPPoA
   Multiplexing:  VC
   QoS:  UBR
   PCR Rate:  0
   SCR Rate:  0
   Autodetect:  Disable
   VPI:  0
   VCI: 38
   Enable:  Yes
   PVC Status:  Applied
    Help...
2) Unfortunately the speedtester doesn't work for my number, I use BT Retail and contacted the moderation team and they got back saying Wholesale have discovered a problem with my number so it's being worked on.
3) http://www.samknows.com/broadband/exchange/NIAL
By the way, here's a speedtest.net result. http://www.speedtest.net/result/1171864419.png
Thanks for your help.
daleski75
Message 6 of 8
Everything looks spot on, do you have any extension leads in your home and is the router plugged into the master socket?
jdowning640
Message 7 of 8
No extension leads - it isn't plugged into the master socket but as I said... I have been getting around 2-3Mbps for a few years but today an engineer came and replaced a wire from the pole to the premises and I am now syncing at 7Mbps... could it take a while for the IP profile to reset?
daleski75
Message 8 of 8
Give it 3 to 5 days and the profile should start to rise
