tonywilliams
Message 1 of 3
What version is the ITV player and Channel 4 player?
What versions of the ITV Player and Channel 4 player are included in YouView? Or are they the cut down versions that are currently in BT Vision?
Tony
2 REPLIES 2
tonywilliams
Message 2 of 3
Re: Lip sync issue
Can I ask you what version of ITV Player do you get on YouView? Is it the cut down version currently on BT  Vision or the full ITV netplayer?
Tony
drhowells
Recognised Expert
Message 3 of 3
Re: Lip sync issue
Hi, the answer is neither of the above. I can't say it is a custom version for YouView, but it is certainly a set top box box version of some kind. As such, the content cannot be guaranteed to be the same as the net version.
