Message 1 of 4
When do i reboot my modem and router?
To get the best possible speeds do i reboot my equipment after the 10 days ?
3 REPLIES 3
Guru
Message 2 of 4
Re: When do i reboot my modem and router?
Yes i wouldn't recommend you reboot anything until after the 10 days, although some people have just rebooted the hub, since that the modem handles the connection.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 3 of 4
Oh **bleep**.
I've rebooted router and modem a few times and i'm only in the first 8 days. Whoops.
Out of curiosity-why shouldn't you?
Guru
Message 4 of 4
The line needs to stabilise, so if you suffer constant disconnects, DLM will think that your line isn't stable on those current speeds, therefore lower your download/upload speeds in the process. All in all, it may actually lower you profile to what it should be.
