howardmoon
Message 1 of 12
When is roll out for my Area MK7
I have checked on the BT where and When site.
It says Accepting orders but no one seemes to be taking them, can any one help.
11 REPLIES 11
Checked2013
Expert
Message 2 of 12
Re: When is roll out for my Area MK7
The accepting orders only relates to the exchange your phone line is connected to and not to the street cabinet. To check to see if you can get Infinity enter your phone number into the following link, if it mentions FTTC and a speed then you can order Infinity: http://dslchecker.bt.com/adsl/adslchecker.welcome
Note: The street cabinet has to be enabled as well as the exchange.
howardmoon
Message 3 of 12
Hi
Thanks for the reply,
I dont have phone line at the moment just moved in.
But did the address and postcode it dont have a date so i guess i will have to wait, or sign up to the 1meg option.
Checked2013
Expert
Message 4 of 12
You're welcome, you won't be sure until you get a phone line, but if you know a neighbours number then you could try that and see what the result is.
miles_safer
Expert
Message 5 of 12
Assuming your part of MK7 is on the Bradwell Abbey exchange like mine you should have FTTP available as there is no FTTC provision in some parts of Milton Keynes having been a test area for FTTP.
You will then have the choice of Infinity 1,2,3 or 4 with speeds up to 300meg and maybe also a fibre phone line instead of a copper one. You should maybe call the fibre team. But I don't have their number to hand here at work.
howardmoon
Message 6 of 12
I am on the Woburn one 😞 makes me smile people post I can only get 8 meg I want fiber. The top speeds I can get is 1 meg
Just a shame bt can't tell you dates when it's coming
miles_safer
Expert
Message 7 of 12
I feel for you I was maxed out at 1.4meg until I got on the FTTP trial a couple years ago. I guess all you can do is keep enquiring as to when fibre will be available to the Woburn exchange.
howardmoon
Message 8 of 12
So that is that fibre in to the house? Can you get up too 300meg then?
Sage
Sage
Message 9 of 12
Yes but he's on a different exchange. There were only a limited number of exchanges in the trial last year.
howardmoon
Message 10 of 12
Yep I know. I have just gone with sky 1 meg is better then nothing I guess.
