Keith_Beddoe
Message 11 of 36
Re: When will BT stop misleading its customers?
@PostTruth wrote:
No, I'd never considered it. The visit was for a problem we've had for many months, namely: when we're using broadband Internet and receive or make a phone call on our landline, the Internet connection is interrupted.
Then I would take advice from this forum first.
Do you have normal BT Broadband, or BT Infinity? I can then move this thread to the correct board for help?
PostTruth
Message 12 of 36
Normal.
Keith_Beddoe
Message 13 of 36
I will move this to the ADSL board. You will see the redirection.
Keith_Beddoe
Message 14 of 36
Which one of these matches your master phone socket?
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
kkkk
Message 15 of 36
I think I would have tried a different micro filter first if you have one in your phoneline.
There are numerous accounts of people being charged for repairs when they should not have been. BT try it on and hope they get away with it.
Webby
Message 16 of 36
I don't think anyone tries it on.
BT only pass on the charge raised by the Openreach engineer.
Sometimes, they have charged incorrectly by closing the job withthe wrong closure code, which generates a charge. In these circumstances the charge customer is often waived.
Keith_Beddoe
Message 17 of 36
Have you tried this arrangement?
Do you have any extensions?
They must come from the back of the removable bottom section of the master socket. This is to make sure that it is totally isolated when you have to prove the location of a fault, as the test socket is located behind that faceplate.
With the faceplate removed, all extensions should be totally dead.
PostTruth
Message 18 of 36
Thanks Keith. I will have a look and get back to you, when I get time.
However, I'd still like to challenge BT's top management about the misleading information they provide. Any idea how? They don't make such things easy for customers. I'd rather not take the matter to Ofcom, but am prepared to if necessary.
licquorice
Message 19 of 36
There is no misleading information, the link Keith posted in message2 makes it perfectly clear what is chargeable and what isn't.
PostTruth
Message 20 of 36
Thanks for your message, Distinguished Guru. I'm not talking about the link Keith posted. Please re-read my original post, which makes it very clear what misleading information I'm referring to.
By the way, I'm finding this "community forum" a little strange. Does it really consist only of BT customers?
