michael21
Message 1 of 21
When will Sky sports 1 & 2 leave DTT freeview/Topuptv?
Any one got information on this please thanks.
20 REPLIES 20
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 21
Re: When will Sky sports 1 & 2 leave DTT freeview/Topuptv?
Some time between 12 and 30 June according to my letter from BT.
michael21
Message 3 of 21
^ Do you get the sky sports channel on Topuptv?
pottyperson
Distinguished Guru
Distinguished Guru
Message 4 of 21
Not TUTV as such, but with a BT card on Freeview channels 41 & 42, which are earmarked for BT Sport from 1 August.
michael21
Message 5 of 21
I did not now about the BT cards so by 1/7/13 the Sky sports channel will no longer be on channel 41/42.
pottyperson
Distinguished Guru
Distinguished Guru
Message 6 of 21
Definitely, but possibly as early as 12 June. It's not yet clear whether existing cards will work for BT Sport or if there will be new ones. Either way, I hope they remember to stop charging for the Sky Sports.
pottyperson
Distinguished Guru
Distinguished Guru
Message 7 of 21
Update. I phoned BT last evening to clarify confusing information in their letter; it appears they sent me the wrong one [sigh]. But during the conversation I managed to get confirmation that existing cards will  be used to provide BT Sport via Freeview channels 41 & 42. (I didn't ask about the future of the current ESPN channel 34.)
To sum up, non-Infinity customers who currently get Sky Sports using a BT Vision viewing card need to hang on to the card when it stops working sometime during the second half of June.
michael21
Message 8 of 21
That good information it the 1st time i seen comformation of the channel numbers.
pottyperson
Distinguished Guru
Distinguished Guru
Message 9 of 21
It's been reasonable to surmise that this would be the outcome but, like you, it's the first time I've heard of any confirmation from BT. Let's hope the adviser was right - she did check and was quite confident.
zulu17
Distinguished Guru
Distinguished Guru
Message 10 of 21
When channels 41 and 42 were first introduced in july 2010 i  they were originally named BT1 & BT2
