nigelf
Message 1 of 4
Where have scheduled recordings gone?
Hi
When I came to look & see what had been recorded last night, one program said "failed to record" and then when I went to scheduled, there is nothing there at all! They are still showing on the program guide. I tried to delete them from the program guide & then set them up again, but there is still nothing in scheduled!
I have turned the box off completely, no difference & I tried a software reset from the maintenance menu, but still nothing. I noticed it had downloaded a new version of the software last night. Could there be a problem with that?
I still have all my recordings, but not sure what to try now - anyone any ideas please?
3 REPLIES 3
Martin--W
Retired BT Expert
Message 2 of 4
Re: Where have scheduled recordings gone?
Hello @nigelf
Would love to see if I can help with this issue. Would you be able to Private Message me with your contact details and phone number?
Martin.
Prius_Taxi
Message 3 of 4
I had this issue over Christmas. I done a soft reset keeping recordings which solved the problem.
The instructions can be found here
http://bt.custhelp.com/app/answers/detail/a_id/52169/~/how-do-i-reset-my-youview-box-from-bt%3F
MitoMan
Message 4 of 4
Did you get this sorted? Funny i have a Humax FREESAT box and had same issues as you, my FREESAT box has completely failed! no hdd.
I am surprised to see many posts on here for Youview recordings/ remote issues, not good at all.
