Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Please can anyone help?
I bought a Kodak C315 printer/scanner to use on another pc. I am now trying, without any success at all to get it to talk to my home hub (or vice versa) so I can use it from my laptop. Upstairs PC runs Vista, laptop and main PC run windows 7. laptop talks quite happily to Epson on main PC but I wanted to use a particular facility on the Kodak. Software has been installed on upstairs PC and laptop]
The printer instructions say either use push button configuration and press the WPS button on the router (can;t find one) or generate a PIn and enter it into my router softwares PIN screen (can;t find it)
Help would be much appreciated as I am now losing the will to live with the stupid thing.
Printer connects properly using a USb but as it is upstairs and I am usually downstairs I'd need too long a lead.
Lack of 5 year old in household does not help:):)
Thank you in advance
have you tried the wifi wizard in the printer setup? if so does it see your hub ssid? again if so and you select it will ask for pin - this is the wifi password for the hub - either on the hub or something you have changed it to. then continue. your printer will now try amnd conect to the hub
Well not quite sure what I did but it now works,, thank you so much for your help lmjolly. It works on the laptop, now to try the pc.
