thompsbd
Message 1 of 4
Where to report packet loss issue in core network?
Hi all.....
I am experiencing approx 50% packet loss to a server located in the netherlands. My connection is absolutely fine, the issue lies deeper in the BT network. Have tried several other BT connections and all experience the same level of packet loss. Using a VM connection or a VPN over BT, the packet loss is zero. Anybody have any idea how/where to report this?
3 REPLIES 3
jac_95
Guru
Guru
Message 2 of 4
Re: Where to report packet loss issue in core network?
Hi thompsbd
please can you post the results of a trace route to the server or site you are having issues with, this will see if the issue is within BT Wholesale's network at all.
An example of a traceroute is below:
C:\Windows\system32>tracert youtube.com
Tracing route to youtube.com [173.194.41.168]
over a maximum of 30 hops:
1 2 ms 2 ms 2 ms BThomehub.home [192.168.1.254]
2 26 ms 25 ms 25 ms 217.32.141.34
3 288 ms 234 ms 25 ms 217.32.141.78
4 30 ms 29 ms 28 ms 217.41.216.202
5 31 ms 28 ms 28 ms 31.55.164.209
6 367 ms 72 ms 146 ms 31.55.164.109
7 29 ms 28 ms 29 ms acc2-10GigE-0-1-0-6.bm.21cn-ipp.bt.net [109.159.248.222]
8 40 ms 38 ms 38 ms core1-te0-15-0-7.ilford.ukcore.bt.net [109.159.248.146]
9 32 ms 33 ms 32 ms peer1-xe3-1-0.telehouse.ukcore.bt.net [109.159.254.213]
10 33 ms 38 ms 33 ms 195.99.126.109
11 33 ms 33 ms 35 ms 209.85.252.186
12 33 ms 34 ms 33 ms 72.14.238.63
13 34 ms 33 ms 34 ms lhr08s04-in-f8.1e100.net [173.194.41.168]
Trace complete.
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
thompsbd
Message 3 of 4
Trace below. Either a BT or Cogent problem I guess....don't know enough about these things to say which. Thanks
Tracing route to hades.feralhosting.com [185.21.216.135]
1 <1 ms <1 ms <1 ms btciscorv220w [10.0.1.1]
2 5 ms 9 ms 5 ms 172.16.18.7
3 * * * Request timed out.
4 14 ms 14 ms 14 ms 217.41.216.109
5 16 ms 16 ms 16 ms 213.120.158.234
6 17 ms 17 ms 17 ms 31.55.165.205
7 16 ms 16 ms 16 ms 31.55.165.109
8 16 ms 17 ms 16 ms acc2-xe-4-1-2.mr.21cn-ipp.bt.net [109.159.250.240]
9 25 ms 23 ms 29 ms core1-te0-13-0-16.ilford.ukcore.bt.net [109.159.250.166]
10 63 ms 24 ms 25 ms peer2-xe11-1-0.telehouse.ukcore.bt.net [109.159.254.118]
11 24 ms 27 ms 23 ms 166-49-211-192.eu.bt.net [166.49.211.192]
12 26 ms 26 ms 26 ms be3035.ccr21.lon01.atlas.cogentco.com [130.117.14.169]
13 23 ms * 23 ms be2316.mpd21.lon13.atlas.cogentco.com [154.54.73.113]
14 34 ms 35 ms 34 ms be2277.mpd21.ams03.atlas.cogentco.com [154.54.62.146]
15 31 ms * * be2322.mag21.ams03.atlas.cogentco.com [154.54.78.106]
16 * * * Request timed out.
17 32 ms 32 ms * 149.11.64.206
18 31 ms * * gobble-gobble-gobble.feralhosting.com [185.21.216.65]
19 35 ms 34 ms 33 ms hades.feralhosting.com [185.21.216.135]
Trace complete.
jac_95
Guru
Guru
Message 4 of 4
thompsbd,
Here's my traceroute to the same server you tried.
Also be aware that some servers are setup to ignore pings.
I don't think it is an issue on the BT Wholesale network though.
my trace route is below:
traceroute to hades.feralhosting.com (185.21.216.135), 64 hops max, 72 byte packets
 1  10.33.73.65 (10.33.73.65)  4.910 ms  3.701 ms  1.753 ms
 2  10.0.0.1 (10.0.0.1)  34.452 ms  37.674 ms  36.316 ms
 3  192.168.133.2 (192.168.133.2)  35.264 ms  34.483 ms  34.344 ms
 4  192.168.71.206 (192.168.71.206)  35.086 ms  35.207 ms  34.212 ms
 5  192.168.69.124 (192.168.69.124)  34.506 ms  53.124 ms  33.669 ms
 6  217.39.0.3 (217.39.0.3)  34.850 ms  34.365 ms  35.778 ms
 7  213.120.178.45 (213.120.178.45)  34.576 ms  34.665 ms  36.688 ms
 8  109.159.249.196 (109.159.249.196)  34.561 ms  35.735 ms  35.724 ms
 9  core2-te0-7-0-14.faraday.ukcore.bt.net (109.159.249.139)  42.750 ms  39.202 ms  40.484 ms
10  host213-121-193-139.ukcore.bt.net (213.121.193.139)  35.562 ms  35.353 ms  35.677 ms
11  t2c3-xe-0-2-2-0.uk-lon1.eu.bt.net (166.49.211.174)  35.351 ms  36.939 ms  35.235 ms
12  be3035.ccr21.lon01.atlas.cogentco.com (130.117.14.169)  36.953 ms  36.187 ms  39.105 ms
13  * * *
14  * * *
15  be2322.mag21.ams03.atlas.cogentco.com (154.54.78.106)  90.452 ms  88.714 ms *
16  * te0-0-0-1.nr12.b021908-0.ams03.atlas.cogentco.com (154.25.1.82)  92.677 ms *
17  149.11.64.210 (149.11.64.210)  145.288 ms  80.610 ms
    149.11.64.218 (149.11.64.218)  76.614 ms
18  185.21.216.67 (185.21.216.67)  85.448 ms  72.841 ms *
19  * * *
20  hades.feralhosting.com (185.21.216.135)  83.213 ms *  97.880 ms
Also if this is a Business related matter and you have BT Business broadband then you can try the BT Business Support Forum by going to http://business.forums.bt.com/
Try a Search
