Newbie
Message 1 of 2
Which TV recorder box is enabled to connect with BT sport on my laptop?
I am looking at a dvd recorder set top box and I note some offer wireless connection to allow your laptop to be streamed to the TV via the box. Does anyone know which boxes are best to use for BT sport? Is is easier to stream wirelessly direct from a laptopto a smart TV and if so what do I need to buy if anything to make it easy? This should be an easy one to answer but I am not very tech savvy! JP
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Which TV recorder box is enabled to connect with BT sport on my laptop?
Not sure about the wireless option, but streaming direct from laptop to telly generally requires just an HDMI lead.
