Message 1 of 4
Which cable needed for WAN extension for FTTP Smart Hub 2?
What type of cable do I need to extend the WAN cable from my wall to my Smart Hub 2 with full fibre?
Also I didn’t know if there’s a particular quality/material of wire needed to preserve the highest level of internet?
I need one about 4 metres long. Do they sell these at the BT shop? Thank you!
3 REPLIES 3
Message 2 of 4
Re: Which cable needed for WAN extension for FTTP Smart Hub 2?
It's gonna be a ethernet cat 5 or 6 cable.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 4
Probably cat 6/7 and should be able to get from Amazon or eBay in whatever length you need
Message 4 of 4
Ok thanks very much!
