Message 1 of 6
Which model is this?
Hi,
I’m looking to get BT Full Fibre 100 but I’m not sure if I have the correct Openreach socket.
I live in a rented property so drilling holes or making any adjustments isn’t allowed... I’m hoping all I need is a converter or an adapter.
Please can someone help before I make the purchase.
5 REPLIES 5
Message 2 of 6
Re: Which model is this?
No, that is just a standard copper master socket. For full fibre, an ONT will need to be fitted and the wall drilled for the fibre to enter the building.
Message 3 of 6
Thank you.
is there anyway of connecting internet with this socket?
Message 4 of 6
Yes, if FTTC is available. Enter your address in the checker and post the results https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 5 of 6
I’ve just done the checker and it’s available.
Having a look at FTTC, Does that still mine BT will have to drill a hole?
Message 6 of 6
No, it will just use the existing copper cable connected to the socket in the picture.
