retsilla
Message 1 of 2
Which phone socket will the BT engineer upgrade?
I have two phone sockets in my house one is an extension which connects to the router. Will the engineer upgrade the one which connects to the router or the one which connects to the socket that connects to the router?
1 REPLY 1
Message 2 of 2
Re: Which phone socket will the BT engineer upgrade?
HE can convert either one you want. My main socket is downstairs but I had my upstairs socket made to the master socket with the VDSL front plate.
