Message 11 of 24
Re: Who can explain this? No Solution required!
@john46 wrote:
speed tests are affected by general internet traffic therefore errors can occur
so you are telling me that all these speedtests that I have done are incorrect, the time it took the 1gb file was also incorrect?
Message 12 of 24
@ray_dorset wrote:
It can only be explained by knowing what your sync speed is. But that info is locked in the modem, so you have to guess what it is. The best guess is to get your IP profile and multiply it by 1.033.
so that would be 77.43 x 1.033, which is 79.98519?
Distinguished Guru
Message 13 of 24
Yeah, but that's only a guess. In order to actually see your sync speed, you need to see it in your modem stats which are locked.
If not, I'll try again 🙂
Message 14 of 24
yes that would be the sync speed
Message 15 of 24
they are never totally accurate there are variables that change constantly
Message 16 of 24
how do you unlock those features of the modem, I am thinking about leaving BT
Expert
Message 17 of 24
you don't need to hack Hg612 you buy yourself a http://www.fritzbox.eu/en/products/FRITZBox_Fon_WLAN_7390/
and see the stats.
or use google to see how to unlock HG612 Smiley Wink
Message 18 of 24
and see the stats.
£212 I must be out of my mind to spend that much money on a router and even if I was, I wouldn't buy this ugly looking router. I would buy tplink's router or e.t.c
I should just hack the modem, I am leaving bt anyway, so, I will get a new one when I get a new contract with sky.
Message 19 of 24
hi riffatiqbal,
I just left sky fibre after a 12 month term with them.
They actually were excellent when I started with them, but slowly got worse over time.
Also, something you should be aware of, once you join with them, you have to use their router, because if you buy your own, they won't give you the necessary details to login to your internet.
And the router they send you is limited.
So be very careful about burning your bridges..
Message 20 of 24
@raven9101 wrote:
hi riffatiqbal,
I see, thank you for that information, I am going to consider that and do a little more research onto that before I buy another contract.
