Message 11 of 12
Re: Who is right? port forwarding ip cams
Each camera must have its own static IP address.
eg
Camera 1    192.168.1.10
Camera 2    192.168.1.11
Camera 3     192.168.1.12
Incoming ports will need to be mapped to the IP address, not the device name.
Port forwarding problems
I will not have any time to provide assistance over the next few days, but you should find plenty of help on my website.
Message 12 of 12
You could try this : -
Give two cameras the same IP address and set the ports to 80 and 81.
I'm assuming you set it from this : - http://i3.tenvis.com/ddns.html
then as Keith says use the ddns address followed by the port, like [ freds.ddns:80 ] or  [ freds.ddns:81 ] and you should get camera 1 on 80 and camera 2 on 81.
If you swap 81:80 in your router you will only get camera 1 as it will " show " port 80 when asking for port 81 and. of course, show port 80 when asking for port 80.
Your HH will need forwarding 80-80 and 81-81 to the single IP address; you cannot forward the same port to different IP addresses eg: port 80 to 192.168.1.44 and port 80 to 192.168.1.45 doesn't work but you can forward two ports to one IP address eg: port 80 to 192.168.1.44 and port 81 to 192.168.1.44
If this helps, good, if it doesn't  AW HECK !!
Cheers
