Message 1 of 1,166
Whole Home WiFi firmware update v1.02.04 build10
I re-enabled steering and then applied the firmware update.
It took a long time - the disks variously went through purple, red and eventually blue.
The web interface is working properly now.
So far so good.
1,165 REPLIES 1,165
Message 2 of 1,166
Re: Whole Home WiFi firmware update v1.02.04 build10
As yet not got the option to upgrade firmware, Do you have a new app as well ?
Message 3 of 1,166
No, my app hasn't updated.
Just went to settings, check for updates.
Message 4 of 1,166
@Dan-O
Is this firmware available to everyone or is it a gradule roll out ?
Message 5 of 1,166
In the browser it says:
Current version v1.02.04 build10
Latest version v1.02.03 build03
That doesn't make much sense.
Message 6 of 1,166
Hi all,
The update is a full rollout so everyone can get the new firmware now. The Android app is available and the iOS app will be released shortly.
You may need to reboot all your discs then check for updates again if you have any problems updating.
Dan-O
Message 7 of 1,166
Hi @Dan-O
Rebooted network, but still stays no update available
Any ideas?
Mark
Message 8 of 1,166
@Dan-O
I have same as Mark, rebooted, checked IOS app and Web interface, - No update available
Starting to get very frustrated now !!
Can BT get this sorted ASAP !
Message 9 of 1,166
FYI, I used the existing iOS app to do the update.
Message 10 of 1,166
Neither works, existing IOS app, or Web interface, you ring "BT" and the help desk says "oh we are not BT and they have not told us of any issues you must be the first" right oh
