Message 1 of 3
Whole home Wi-fi
How many discs can you have in the Whole Home Wi-Fi ? Is it just one extra making 4 or can you add more than just one to an already three system.
Bassed on the answer above, could you add a two disc system to a three disk system creating a 5 disc system? Ie, just one disc directly connected to the router and 4 further disks in a daisy chain to it
Cheers.
2 REPLIES 2
Message 2 of 3
Re: Whole home Wi-fi
Hi @Chief  Check out This Thread which shows that up to 6 disks are able to be used.
Cheers
John
Message 3 of 3
Hi @Chief. You can have up to 6 discs in any combination. You can do what you describe with your 5 disc system to cover a long area.
But be aware that you can't "force" a daisy chain if that's what you're aiming to do (is that to cover a long area?). Although that shouldn't matter as the system will work out the best connections from where you've put the disc (follow the instructions when you add a new disc in the App).
