So over the last 10 days I have had to reinstall my WHWifi app numerous times. Keep getting this message after it has been left for a day or so
Any ideas please?
NWDIS-001 means the network can’t be discovered
1. Check their device is actually connected to WHW SSID and not your router.
2. Make sure router Wi-Fi has a different name or is turned off.
3. Make sure if you have a VPN that it allows local network traffic or turn it off temporarily.
4. Reboot all discs and confirm if the error continues.
