nomad2k3
Message 1 of 75
Why are you slowing down my connection?
So a few months ago on this very forum I complained about super slow speeds on my service, of around >.5 mb/s
This was resolved eventually and was put down to a fault at the local exchange.
last month I decided to cancel my subscription as £26 a month I felt  was too much for the service I was getting.
I was offered a reduction to £15 a month with the same service I had previously.
I enquired about this and was told I would get the "exact same service", thankfully I record all my phone calls made to companys so I have it on record.
However it seems since I started to pay the lower price, I also have been given a lesser service.
My usual speeds of 6mb/s have now been reduced to around 3mb/s
from 550-600kb/s to 250 kb/s
I have called customer service about this and they state "that is the maximum speed you can get"
I have the on voice record, I also have around 3 different recordings from several months ago stating I was getting 6mb/s from various BT employees.
I can no longer stream HD content as I could for the past several years, even SD content from youtube now buffers.
Trust me when I say I went with BT because it is the fastest service around although I now hear XXXXX are quicker, but BT locked me into a new contract and then gave me a lesser service.
To add insult to injury BT keep sending me leaflets about BT Vision HD lol.
Bt speed tester results
 Download speedachieved during the test was - 3.08 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 3.5 Mbps
Upload speed achieved during the test was - 0.3Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
ADSL line status
Connection Information
Line state    Connected
Connection time    3 days, 02:13:20
Downstream    3,968 Kbps
Upstream    448 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Modulation    G.992.1 Annex A
Latency type    Interleaved
Noise margin (Down/Up)    14.6 dB / 27.0 dB
Line attenuation (Down/Up)    45.5 dB / 26.5 dB
Output power (Down/Up)    6.0 dBm / 1.9 dBm
Loss of Framing (Local/Remote)    0 / 0
Loss of Signal (Local/Remote)    0 / 0
Loss of Power (Local/Remote)    0 / 0
FEC Errors (Down/Up)    18755 / 77
CRC Errors (Down/Up)    17871 / 32
HEC Errors (Down/Up)    28890 / 26
Error Seconds (Local/Remote)    4859 / 56
Why is my service being restricted?
74 REPLIES 74
Message 2 of 75
Re: Why are you slowing down my connection?
hi your speed has been reduced because your noise margin has increased due to your hub disconnecting your service is not being restricted due to a lower cost
I suggest you contact the forum mods they should be able to reset your noise margin reset for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Guru
Message 3 of 75
Looking at the errors on your line, I would say you could maybe expect another drop in IP Profile. There is also a lot of noise which will decrease the speed of your line.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Guru
Message 4 of 75
It's not being restricted either manually ... or on purpose.
It's actually restricted because the connection is running a 14.6db noise margin.
Which infers you have either, line noise, impulse noise at home, or you've been resetting it too much.
nomad2k3
Message 5 of 75
So how exactly do I get them to fix this? My router is connected directly to the master socket in my house.
It was not that long ago, a technician came out and tested my line and said it was fine, altthough he did change a small box that is fitted to the line.
Also AFAIK BT are responsible for the line upto the master socket?
thanks for the replies.
Guru
Message 6 of 75
Firstly you have to determine is it ... you? .... or "them". 🙂 go read http://forumhelp.dyndns.info/speed/first_steps.html
nomad2k3
Message 7 of 75
Ok let me run those tests.
Im not sure about the noise crackling one, I dont actually have a house phone to plug in, I only use a mobile we got sick of those cold calls lol.
nomad2k3
Message 8 of 75
Ok so I asked a neighbor for a phone and there seems to be no crackling or hissing on the line.
The master socket is like the one pictured in the help link, I.E. it has a line across the top third of the socket.
Connection time    0 days, 00:05:44
Downstream    5,856 Kbps
Upstream    448 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Noise margin (Down/Up)    6.2 dB / 27.0 dB
Output power (Down/Up)    9.0 dBm / 1.9 dBm
FEC Errors (Down/Up)    25 / 0
CRC Errors (Down/Up)    4 / 0
HEC Errors (Down/Up)    66 / 0
Error Seconds (Local/Remote)    3 / 0
BT SPEEDTESTER RESULTS
Download speedachieved during the test was - 4.7 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 5.17 Mbps
Upload speed achieved during the test was - 0.32Mbps
Ok when I was undoing the socket it seems my wife has plugged in a power  cable extension with one of those aroma electric therepy air fresheners into it, it was right by the socket and adsl filter, could this cause the noise?
 Man LOL
Its still not up to the usual speed, but its a bit better.
nomad2k3
Message 9 of 75
ADSL line status
Connection time    0 days, 00:19:02
Upstream    448 Kbps
ADSL Settings
VPI/VCI    0/38
Type    PPPoA
Noise margin (Down/Up)    6.1 dB / 27.0 dB
FEC Errors (Down/Up)    91 / 0
CRC Errors (Down/Up)    20 / 0
HEC Errors (Down/Up)    222 / 1
Error Seconds (Local/Remote)    14 / 1
It seems I am still getting errors??
nomad2k3
Message 10 of 75
Router just disconnected for no reason,
ADSL line status
Connection time 0 days, 00:03:06
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 6.6 dB / 28.0 dB
Line attenuation (Down/Up) 45.4 dB / 26.5 dB
Output power (Down/Up) 6.2 dBm / 1.9 dBm
FEC Errors (Down/Up) 147 / 0
CRC Errors (Down/Up) 52 / 0
HEC Errors (Down/Up) 25 / 0
Error Seconds (Local/Remote) 34 / 0
Download speedachieved during the test was - 2.78 Mbps
Upload speed achieved during the test was - 0.34Mbps
Still connected to test socket, nothing plugged in near socket.
ADSL line status
Connection time 0 days, 00:09:00
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Noise margin (Down/Up) 6.4 dB / 28.0 dB
FEC Errors (Down/Up) 607 / 1
CRC Errors (Down/Up) 103 / 0
HEC Errors (Down/Up) 81 / 0
Error Seconds (Local/Remote) 71 / 1
lots and lots of errors
