Message 1 of 10
Why does BT tell me I can get Superfast Fibre when I don't get anything like those speeds?
Why does BT tell me I can get Superfast Fibre when the maximum download speed is about 25 Mbps and upload less than 3? (today upload is 0.8).
9 REPLIES 9
Message 2 of 10
Re: Why does BT tell me I can get Superfast Fibre when I don't get anything like those speeds?
Enter your phone number into this form and display the results here, but edit out your phone number before you post the results.
Message 3 of 10
Here you go! I have a feeling it's because I'm too far from the cabinet.
Message 4 of 10
You would be correct in that assumption.
Message 5 of 10
Although it would help if they were more upfront when predicting the speed. If I go online and input my phone number and address, they offer me Fibre 2.
Message 6 of 10
As you can see, that would not be possible on your line.
Message 7 of 10
I do see, but my point is that is not what they advertise.
Message 8 of 10
I have some sympathy as they always advertise 'up to' but the info on what you are likely to get is there when you order as I remember ?
Message 9 of 10
Fibre 2 isn't just extra speed it also has more virus protect licenses & cloud storage as well hence why it's still offered when you can't get the higher speeds
Message 10 of 10
If that's the reason, they should change the name.
