markca
Message 1 of 2
Why does my BT hub crash every day?
I didn't have this problem with Sky fibre!
1 REPLY 1
imjolly
Message 2 of 2
Re: Why does my BT hub crash every day?
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 Are you using the test socket with a new filter?
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
