Webby
Message 31 of 45
Re: Why does my Line Speed Drop?
Looks like a BT Wholesale RAS/software issue causing the IP profile not to be set correctly
RogerB
Guru
Message 32 of 45
 The reason the line is strangled is because it's running a high margin on both paths, with associated INP.
If you look at the stats it's doing 13 and 14db margins ... a tad away from orange banding. Something (impulse noise) or the user has caused that to happen since line connection conception, maybe restarts or even noise on the line, either way the margins are high.
DanielS
Moderator
Moderator
Message 33 of 45
Hi @abathingape,
We'll take a look into it all for you. You can reach us by clicking on my user name and then on contact the mods. Fill that form in and we'll get back to you within a few working days.
I want to thank everyone that has posted on this thread offering help. It's great to see the Community out in force supporting each other.
DanielS
Webby
Message 34 of 45
Roger - that doesn't explain why the IP profile is down at 22meg with a sync of 50meg.
RogerB
Guru
Message 35 of 45
There's a distinct possibility the connection crossed the 15db margin threshold and entered orange banding ... if so, it's effectively banded regardless of its sync rate, even if the margin has now fallen below that threshold.
Webby
Message 36 of 45
Got any documentation which explains that? Never seen it on a circuit before
RogerB
Guru
Message 37 of 45
Really? ... you surprise me. Thought you to be a knowledgable chap. 😉
Webby
Message 38 of 45
Was a genuine question 🙂
I've never saw a circuit artificially with a sync rate double of said limit.
abathingape
Message 39 of 45
thanks @DanielS - message sent via 'contact the mods'.
Hope this can be resolved ASAP.
abathingape
Message 40 of 45
Just an update.  No reply from the mods yet but since my last restart, there have been no resyncs.
Connection is still:
Sync 50142 / 9997 kbps
Attainable Rate is 49336 / 17002 kbps
Profile is still 23mbps though 😞
