zapper
Message 11 of 21
Re: Why has my broadband speed dropped to 1/10th of what it was?
Hi,
Which stats do you want? These are the only ones I know how to check. Like I said it was connected for 3 days and a few hours before it disconnected again this afternoon.
john46
Message 12 of 21
those are the ones thanks the reset was caused by a noise margin drop
imjolly
Message 13 of 21
banding has not released thoughSmiley Mad
john46
Message 14 of 21
not yet hopefully at the next drop
zapper
Message 15 of 21
Hi, me again
The speed has dropped once more. The router started disconnecting constantly about two weeks ago and so of course the speed was limited once again. I was not switching the router on and off, I would switch it off at night and turn in back on in the morning like I've done without problem for years.
The connection went from around 20Mbps to 2Mbps in the space of a week. I left the router switched on and eventually it stopped disconnecting and had a connection for 6 straight days before it disconnected again. I was expecting the speed to increase after that disconnect but it has actually dropped even lower to just over 1Mbps. What else can I do except leave the router on and hope the speed increases? It is ridiculously slow now.
john46
Message 16 of 21
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
you are on ADSL2+ which is more noise aggressive and this is where a stable 24/7 connection is needed to maintain the best possible speeds
zapper
Message 17 of 21
I dialed that number, my line was totally quiet.
I have kept the router switched on for the past three weeks but all that happens is that the connection disconnects every few days and my broadband gets slower and slower.
It is now the slowest it has ever been, ridiculous. I am going to cancel my broadband connection as I'm sick of it.
john46
Message 18 of 21
your connection should not be dropping like that are you connected to the test socket if you are and it is still dropping then you need an engineer visit
zapper
Message 19 of 21
Our house only has one old style BT socket.
imjolly
Message 20 of 21
have you replaced the filter?  have you checked for interference
interference causes
 if nothing then you need an engineer visit as you seem unable to maintain a stable connection and without that your conenction is never going to improve
phone customer services
08001114567
