Zacg99
Message 1 of 2
Why have I got 2 bell wires?
I have a really slow connection speed and I was told that I should remove the bell wire in my master socket. I looked at the wiring and there are TWO orange wires going into the same terminal. Do I remove them both or just one?
1 REPLY 1
Guru
Message 2 of 2
Re: Why have I got 2 bell wires?
Do you have 2 phone extensions?
Or even an external ringer?
Whatever the reason the only terminal connections you need for broadband and phone are on terminals 2 and 5.
All others can be disconnected properly.
I need to remind you also .... that to intervene on your master socket is unlawful.   😉
