Message 5 of 14
Why is my internet capped?
Why is my internet capped. I was told by Openreach I should be betting 30mbps and I’m getting below 15mbps. I can’t even pass 15mbps and the max it goes to is 14.9mbps sometimes. I have a picture.
13 REPLIES 13
Message 1 of 14
Hi, I reported to Openreach that I had slow internet the other day and they came back and said I should be getting at least 25mbps - 35mbps. I’m a bit confused how I’m very low under that and only getting 15mbps. It seems like my internet is CAPPED because it can’t even go past 15mbps. Why is it capped?
Message 2 of 14
Re: Why is my internet capped?
@GuyHomer277
You will never get those sorts of speeds on an ADSL connection. Are you sure you are not on a superfast "fibre" connection?
Message 3 of 14
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 14
I’m not sure. I was told that I should get those speeds.
Message 6 of 14
if you can post the information I requested then you can see if forum members can help you
Message 7 of 14
Can you post the hub connection stats from Advanced settings/technical log/information.
Message 8 of 14
Would you like my data rate and maximum data rate?
Message 9 of 14
Would you like my data rate and my maximum data rate?
Message 10 of 14
@GuyHomer277
just post the stats i requested
