Message 1 of 8
Why is my sync rate lowest ever
When i first started on Infiniti 2 I was getting a sync about 64Mb/s and a Max attainable of aboyt 72Mb/s
Now 8 months into it and now my sync is 47Mb/s and Max attainable is the same.
Only change is my SNR ratio for downstream is 7.4 instead of the usual 5.9.
Brand new microfilter and modem cable installed both approved by BT for SIN498
Bt claimed to have resynced the line twice now and the speed only ever seems to decrease.
Thanks for any help in Advance
Robert
7 REPLIES 7
Recognised Expert
Message 2 of 8
Re: Why is my sync rate lowest ever
Please post your full Home Hub router stats
Learn how from here Broadband Top Tips
Full router stats are key to any speed & connection issues.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 3 of 8
So this is the BT whole line check
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ62061128
Firmware version:
SG4B1000B316
Firmware updated:
03-Aug-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 12 Minutes 30 Seconds
Data rate:
15.00 Mbps / 44.09 Mbps
Maximum data rate:
17474 / 73697
Noise margin:
6.4 dB / 8.1 dB
Line attenuation:
18.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
22 MB Uploaded / 102 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
Cyberdyne
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
Cyberdyne-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:0E:91:45
Software variant:
Boot loader:
7.33.1
and the BT wholesale
Like I say the faceplate and the modem cable have been changed. the only thing left to change is the router itself and go back to my old hh5 type b
Thanks in Advance
Recognised Expert
Message 4 of 8
What is the Premise Environment at the foot of that BT table?
Message 5 of 8
Moderator
Moderator
Message 6 of 8
Hi @rrodgers73 and welcome.
Your stats confirm a connection time of just 12 minutes. Is the connection dropping or have you been resetting the hub?
Cheers
David
Recognised Expert
Message 7 of 8
Are you getting those stats from the hidden test socket?
Message 8 of 8
Hi Sorry I reset the hub just before I took the stats to ensure it was not resolved.
And yes I am plugged into the master socket with the faceplate off.
Another disconnect today and now it has dropped to 40.
3 days in a row it has dropped now
