My download speed has become very slow in the last couple of months. 0.21mps in the morning. It used to be 2.5mps. The upload speed is 1.02mps which is about the same as it has always been. The problems seem to have started when work was carried out installing a new broadband cabinet nearby. Basically its completely unusable in the evening 1. Best Effort Test: -provides background information. Download Speed 0.21 Mbps 0 Mbps 0.25 Mbps Max Achievable Speed Download speedachieved during the test was - 0.21 Mbps For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps. IP Profile for your line is - 0.25 Mbps 2. Upstream Test: -provides background information. Upload Speed 1.02 Mbps 0 Mbps 0.83 Mbps Max Achievable Speed Upload speed achieved during the test was - 1.02Mbps Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance. Please visit the FAQ if you are unable to understand the test results Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Handback Threshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper High Low High Low VDSL Range A (Clean) 16.5 9.3 1.2 0.8 7.1 Planned -- -- VDSL Range B (Impacted) 14.3 5.8 1.2 0.6 3.4 Planned -- -- ADSL Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date Left in Jumper WBC ADSL 2+ Up to 3 -- 1.5 to 5.5 Available -- -- ADSL Max Up to 2 -- 1.5 to 4.5 Available -- -- WBC Fixed Rate 1 -- -- Available -- -- Fixed Rate 1 -- -- Available -- -- Other Offerings Availability Date ADSL Multicast -- -- -- Available -- -- Premise environment Status Bridge Tap U VRI N NTEFaceplate N Last Test Date 07-08-2018 For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage. This line is on a Market A Exchange. For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions. In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values. Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises. The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 15-Mar-2018. If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated. Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check. Note: Thank you for your interest.
@Cripper2 I'm sorry about the problem with your download speeds. Can you post your router stats and we'll take a look?
DSL Line Status: Connected DSL Up Time: 9 days 0 hours 34 minutes
DSL Modulation Type: ADSL_2plus
Annex Type: Annex A/L
Upstream
Current Rate 886
Max Rate 886
SNR Margin (db) 6.6
Line Attenuation (dB) 30.8
Errors (pkt) 469
Downsteam
Current Rate 283
Max Rate 4356
SNR Margin (db) 19.6
Line Attenuation (dB) 50.5
Errors (pkt) 438
