travva
Message 1 of 5
Why moved?
I posted a lengthy message regarding my difficulties with my Inifinty order.  The Moderator has moved it to the "Billing" section.  Can you move it back?  My problem is not a billing issue but an installation problem.
4 REPLIES 4
imjolly
Message 2 of 5
Re: Why moved?
I think it was moved to the billing/ packages board as it is a problem getting your infinity package installed and this board is for problems with your connection after you have infinity installed
travva
Message 3 of 5
Re: Why moved?
Thanks for the reply but I posted my issue here as it is almost identical to "Another Infinity postponed" which is on this board and talks about order and installation problems.  Can you move me back?
imjolly
Message 4 of 5
Re: Why moved?
Your post is on the correct board and will get replies
john46
Message 5 of 5
Re: Why moved?
your other post on the billing board has been picked up by one of the forum mods if you reply to their contact link they will help you with your problem
